could a cisco 2801 router do VPN?
i have 50 remote sites each having a Cisco 2801 router with a T1 wic card connecting back to H.Q. I would like to setup a VPN connection as a backup plan, does Cisco make a DSL wic card for a 2801 router? If so, could i setup a IPSec connection from a 2801 router back to H.Q. as a backup connection?
Overall Rating: 5 (1 ratings)
Paolo Bevilacqua Mon, 06/18/2007 - 10:59
Sure, the card is HWIC-1ADSL and with any "K9" image you will be able to do hardware-accelerated IPsec VPN using the embedded module that all the ISR router have.
Hope this helps, please rate posit if it does!
