CDR
Jun 18th, 2007
Can CDR be exported as a csv file in CCM5.x?
Is there a link discussing that?
mchandak Tue, 06/19/2007 - 03:49
If you are looking for something similiar to CallManager 4.x, yes this option is available with CM 5.x as well. Please check
http://www.cisco.com/en/US/customer/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00806abc20.html
Also, since CDR on CallManager 5.x is saved in flat files and not Database, you can configure CM to move it to a different server as well using SFTP. Checck the following:
http://www.cisco.com/en/US/customer/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00806ad59b.html
Hope this helps
