06-18-2007 11:18 AM - edited 03-05-2019 04:48 PM
Hi, there's something I don't understand.... when you have a tunnel interface, and traceroute to the tunnel destination - why don't you get the hops inbetween the tunnel - the real hops that the tunnel is being formed over?
Thanks, LisaG
Solved! Go to Solution.
06-18-2007 11:36 AM
Becuase the ICMP packets are encapsulated (or enveloped) inside GRE packets and are never seen by the intermediate routers. Only when the tunnel destination is reached is the packet de-encapsulated.
If you want to trace the tunnel's path trace to the tunnel destination and not the tunnel's interface IP.
06-18-2007 11:45 AM
Lisa
If you want to put in a static route that will carry traffic through a GRE tunnel then the next hop in the static route should be the tunnel interface address of the remote router.
Rick
06-18-2007 11:36 AM
06-18-2007 11:41 AM
THANKS!
06-18-2007 11:42 AM
By the same token, if you want to put in a static route to through an IPSEC/GRE tunnel, is the next hop supposed to be the tunnel destination, the ipsec peer or the next hop in the physical path?
THanks, Lisa G
06-18-2007 11:45 AM
Lisa
Rick
