DMZ server authentication issue
Jun 18th, 2007
I have a DMZ (192.168.4.0/24) setup for my web server on a PIX 515. When I put a laptop (running XP Pro) in the DMZ to test connectivity to the inside it is able to hit all the resources with a ping so I believe that traffic is flowing correctly. Then when I tried to join the laptop to my Active Directory domain I received an error stating that "no endpoints available from the end point mapper". This also happened with a Windows 2003 server but did not happen with a Windows 2000 server. Has anyone else ran into this and know what port need to be opened to allow authentication traffic with the newer Windows operating systems?
I've been trying to troubleshoot this as a Windows issue but I know it's not a DNS issue which is what I'm being told. Any help is appreciated.
Overall Rating: 4 (2 ratings)
musethur Mon, 06/18/2007 - 23:13
  • Cisco Employee,
I have not come across such an issue b4, but to tell you a suggestion. You should enable logging on terminal (monitor) or console and start analysing the message which will tell you why the pix is dropping the AD join packets. This will help you in identifying the ports that need to be opened.
HTH, Murali
