can ping remote node access shares but no http over the vpn
Jun 18th, 2007
I have setup a site to site vpn and can ping the remote and access shares etc
but when trying to access the sage web based client the remote returns page not found i think its something to do with the nat or ACL not allowing http traffic down the vpn
any thoughts welcome
sundar.palaniappan Mon, 06/18/2007 - 16:28
  • Green, 3000 points or more
It could be the crypto access list/NAT depending on how it's configured. Another potential issue that can cause similar problems is MTU due to IPSEC overhead. Try configuring the command 'ip tcp adjust-mss 1440' on the LAN facing interface and see if it helps.
If you are still having issues please post your configurations.
Sundar
