Joe Clarke Mon, 06/18/2007 - 15:47
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
A true duplicate IP in your network is a bad thing. To keep DFM from showing duplicate alerts, you need to either unmanage the interfaces you do not care about, or correct the duplicate address on the network. To unmanage interfaces in DFM, go to DFM > Device Management > Device Details.
dmamattah Thu, 06/21/2007 - 08:13
thank you for your reply. Actually there are no true duplicate IP. Event details displays below information eventhough devices A,B and D have their unique IP, hostname and domain names
Event_Description Duplicate
Component IP-address of A [domain name of the device A]
Netmask
NetworkNumber
DuplicatedBySystems B, C,D, etc
Address IP address of A
what might be causing this?
thanks
Joe Clarke Thu, 06/21/2007 - 08:17
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
DFM uses SNMP polling of the ipAddrTable to determine what IP addresses are configured on which interfaces. There was a bug where if a duplicate IP address had occurred, and was fixed, the event would not clear out of DFM. That should be fixed now, but if it still happens, you can manually clear the event, then it should not come back. Note: you need to be running DFM 2.0.6 or higher for these fixes.
dmamattah Fri, 08/24/2007 - 14:41
Will installing Microsoft Service pack 2 have any cause any problem to
Ciscoworks LMS 2.6,
RME 4.0.5,
Ciscoview 6.1.5
campus manager 4.0.8
IPM 2.6
Fault Manager 2.0.8
Joe Clarke Fri, 08/24/2007 - 15:45
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Yes. Currently, Windows 2003 SP2 is not supported by LMS 2.6. LMS 3.0, however, does support SP2.
dmamattah Fri, 08/24/2007 - 17:12
Is there a work around with installing the SPK2
Joe Clarke Fri, 08/24/2007 - 23:47
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You have to uninstall (i.e. back down to SP1) it if you want TAC support.
dmamattah Wed, 10/03/2007 - 10:28
How do i generate a report for only Active Connected Ports for all my switches and routers in RME. I dont want the report to contain ports which are down
Joe Clarke Wed, 10/03/2007 - 10:35
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
There is no way to get this report in RME. Campus Manager 5.0 offers a report that does provide this information.
