Gatekeeper Alias Static Command with Priority
Jun 18th, 2007
I am using Gatekeeper to control calls between a CallManager cluster and CME. When using the alias static command in gatekeeper, calls to CCM phones load balance between the Sub and the Pub. I cannot find a way to implement a priority as you can with the zone prefix command. Anyone know how to implement priorities on the alias static command?
Thanks!!!
Adam
mwadam Fri, 06/22/2007 - 13:14
Thanks for the response. I was thinking there was not a way, but needed to ask.
So now let's approach this scenario from the other side. The Gk has an alias static from a remote H323 device (CME in the case). Since you cannot register CME to the Gk because he has an alias static, how do you get calls from CME into the GK destined for other sites?
Thanks!!!
Adam
