IPCCX Recording Format
Jun 18th, 2007
Need assistance in understanding the recording files format. For example:
where xxxx is the agent extension followed by the agent ID. Just trying to figure out if those middle 6 digits represent anything. Any assistance is greatly appreciated. Thank you.
didyap Fri, 06/22/2007 - 11:57
The naming convention used for is as follows:
Where Date the file was recorded
Time the file was recorded
Counter that is reset every time the agent logs in. It is incremented
sequentially starting from 00000 every time a recording of that agent is made
during that session.
The extension of the agent recorded
The ID of the agent recorded
furqanali Fri, 06/22/2007 - 22:45
Is it mandatory to have the voice gateway on the same network where the call is being recorded. What if my voice gateway is located at service provider end.
vjemin Sat, 02/16/2008 - 06:44
Is it posible to change this naming convention?
