CSM Module
Jun 19th, 2007
I have a core switch 6509 with CSM Module installed in it, so anyone know how to find documentations regarding this module and how to deal with it as will as configuring it.
Talal Habeeb
Jon Marshall Tue, 06/19/2007 - 00:40
Hi Talal
Attached is a link to configuration documents for the CSM module. These should give you a good start.
http://www.cisco.com/en/US/products/hw/modules/ps2706/products_installation_and_configuration_guides_list.html#anchor12
You configure it via the switch CLI on a 6500.
I'm sure you will have other questions. If you do there is a separate forum for load balancing issues :
Network Solutions -> Application Networking.
If you post your questions in that forum you will get answers from the relevant experts.
Jon
habeeb_talal Tue, 06/19/2007 - 00:53
Hi jon,
thank you very much for the help, could you please attach the link for this separate forum?
