RHI on Anomaly Guard Module
Jun 19th, 2007
is it possible to disable RHI on a Cisco Anomaly Guard Module installed in a cisco 7613?
In the preseent scenario I am doing long-diversion, taken-care of by separate routers modifying the BGP next-hop to a Guard appliance behind the 7613.
Keeping the 7613 routing table unaware of the change greatly simplifies the re-injection process as it is not necessary to use VRFs.
Now I plan to use a Guard Module internal to the 7613 instead of the appliance, but the RHI static route injection would force me to use VRFs, which I do not want.
Thanks in advance
