VPN connection with dyn IP
Jun 19th, 2007
Hi there,
Is it possible to open a VPN Tunnel from an ASA to PIX but the PIX has a dynamic IP address?
We have some Branch offices using BT Broadband to log in to our network via VPN. Now the company wants to open VPN connections from our Headquarter to the Branches. Is that possible but I couldn't found a command in the comand reference doc.
thanks in advance
Hi Juergenrieger
This is not possible, you just need to configure the Remote PIX with the address
of the Central PIX, but on the Central PIX you would need to set the ISAKMP peer
with 0.0.0.0 netmask 0.0.0.0.
isakmp key address 0.0.0.0 netmask 0.0.0.0 (Central site)
isakmp key address netmask 255.255.255.255
The remote PIX must initiate the connection as this knows about the PEER where the
Central site does not, this has been configured to dynamically accept connections from anywhere knowing the wild-card pre-shared key.
Regards MJ
