gw to gw vpn connection
Jun 19th, 2007
Dear All,
from my vpn server side they have configured gw to gw VPN.So they have provide us following info.
Stc peer address is abc.abc.abc.abc
Encryption (3DES)
Authentication pre-share key : *********
Hash authentication (D5)
Diffie-Hellman Group-1
but we don't know how to connect with VPN server.we have broadband connection with zyxel router.
please help me that how i can connect with my server.
spremkumar Wed, 06/27/2007 - 23:56
Hi Rajesh
Do you have Cisco VPN Client installed in your PC which can access the VPN server with the credentials provided...
AFAIK i dont think you can do much with the Zyxel router to access the vpn server.
In general conditions you can do simple configuration to make ur client access the vpn server..
You can refer the below link for the same..
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a008009484e.shtml
regds
