Router/Switch config
Jun 19th, 2007
I would like to know what is the best configuration to connect 2 Routers 7206 to 2 Switches 3750 . The best configuration between Routers , between Switches and between Routers/switches . Thanks .
smothuku Tue, 06/19/2007 - 04:34
Hi ,
Go for HSRP between routers and switches..
We can achieve redundency if you go for HSRP.
guruprasadr Tue, 06/19/2007 - 04:46
HI, [Pls Rate if Helps]
Apart from HSRP, you can also use OSPF to vary the Primary Links & Secondary Links between the Switches & Routers. Using "COST" as a Variation factor.
OSPF - IEEE Standard Protocol.
Between Routers:
You can create a "AS" & maintain a IBGP Sessions (or) you can also create a GRE Tunnel.
Between Switches:
You can use OSPF single area "area 0"
1st Switch: Cost 10
2nd Switch: Cost 100
Between Routers & Switches:
OSPF can be used. But, you need to redistribute the BGP AS into OSPF network using Route-Map command.
PLS Rate if Helps
Best Regards,
Guru Prasad R
