SQL Function Support
Jun 19th, 2007
Does this function is support in the IPCC Script in the DB Get Step ?
SELECT MAX(expression )
FROM tables
WHERE predicates;
Using IPCC version 4.0(4)_Build140
lpezj Tue, 06/19/2007 - 05:41
  • Gold, 750 points or more
I think that the best thing is that you try the query. You will need to deploy IPCC Express Premium version.
The Cisco documentation says this:
You cannot create Join queries that retrieve columns with the same name from
different tables. (For example, you cannot create ?select a.x, b.x from a,b? and
?select a.x as y from a?.) Similarly, you cannot make aliases of column names.
The SQL statements SELECT count(*) and SELECT min(*) are not supported.
So if select min(*) is not supported is lekely that select max(*) is no supported too. So the best thing, try it.
Hope this helps,
Juan Luis
smaruvada Wed, 06/20/2007 - 20:58
Depending on whether you have standard/premium/enhanced version, you can use the above query. If you can do DB dips, you should be able to run the above query w/o issues.
Sunil
