06-19-2007 05:46 AM - edited 03-05-2019 04:48 PM
Hi, I ve a new 2821 and and old wic 1 enet?
Is compatible this wic with this router?
Best regards
Solved! Go to Solution.
06-19-2007 06:02 AM
If you are connecting this 2821 router to 2 ethernet devices, the ethernet ports supplied by this router should be enough.
06-19-2007 05:53 AM
It wasn't supported under 2600 series so I highly doubt it's supported under the 2800 series.
http://www.cisco.com/en/US/products/hw/routers/ps214/products_tech_note09186a00800ae37f.shtml
06-19-2007 05:58 AM
The cisco 2821 has 2 fastethernet ports,I need to connect one to the swicht and the other one to the lmds device.. is possible? or Ineed ti purchase a 1-lan HWIC or something like this?
06-19-2007 06:02 AM
06-19-2007 06:06 AM
the 2821 is wic orhwic empty.
I want to insert a wic 1adsl only.
http://www.cisco.com/en/US/products/ps5854/prod_models_comparison.html
The 2821 has 2 lan ports.. one will the used to the lan and the other one to the lmds ethernet port.
Its ok?
