PIX Message Code
Answered Question
Jun 19th, 2007
What is the PIX Message code for when the config or policy has been changed on a PIX firewall?
Correct Answer by JORGE RODRIGUEZ about 10 years 1 month ago
It could be 111002 or 111008 ,this code at least indicates the following:
111002
Error Message %PIX-5-111002: Begin configuration: IP_address writing to device
Explanation This message is logged when you enter the write command to store your configuration on a device (either floppy, Flash memory, TFTP, the failover standby unit, or the console terminal). The IP_address indicates whether the login was made at the console port or via a Telnet connection.
111008
Error Message %PIX-5-111008: User user executed the command string
Explanation This syslog message is for accounting purposes. The user entered a command that modified the configuration.
http://www.cisco.com/en/US/docs/security/pix/pix63/system/message/pixemsgs.html
Rgds
Jorge
Overall Rating: 4 (1 ratings)
Correct Answer
JORGE RODRIGUEZ Tue, 06/19/2007 - 06:46
  • Green, 3000 points or more
111002
111008
Rgds
Jorge
