Cisco GET
Jun 19th, 2007
I have read about Cisco GET VPN in the new features section of release 12.4(11)T. I don't see in the examples any use of EIGRP in an MPLS situation. Does anyone know if this is supported? I am specifically looking to see if there can be any to any connectivity amongst our remote sites using EIGRP to dynamically learn routes with GET enabled. If it is supported does it require all neighbors to be defined, or will the neighbors be learned automatically as they would on the same LAN segment?
