Difference between CQ and WFQ
Jun 19th, 2007
I'm trying to test different scheduling policies and I'm studing all scheduling algorithm. But I can't understand the difference between CQ and WFQ algorithm. In which case should we use WFQ algoritm rather than the other?
Overall Rating: 5 (1 ratings)
srimural Fri, 06/29/2007 - 20:27
CQ and WFQ work in different methods. if you have a specific set of traffic and you want to give specific bandwidth for each classes you can use CQ. But in case of WFQ, you dunno what all traffic flows and you want to give better priority for low volume applications But there is no bandwidth guarantee. it will divide the whole bandwidth available with the number of traffic flows. This makes the low volume get better bandwidth.
Thanks and Regards,
[email protected]
