Variable Length On-Net Dial Plan "
Jun 19th, 2007
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_implementation_design_guide_chapter09186a00806375f2.html#wp1043484
In the section of "Variable Length On-Net Dial Plan "
It states that:
Between sites, users dial an access code followed by a site code and the destination's on-net extension.
My question is: I understand we can use site code to avoid the overlap extensions. But why we need an access code, can we just have site code plus the extension? Thanks
Majdi Harb Tue, 06/19/2007 - 09:12
  • Silver, 250 points or more
as stated also in this section: the goal of the access code is to enable the on-net dial plan to differentiate between extensions that would overlap if a uniform abbreviated dial plan were implemented.
yes u can just have a site code plus the extension, this depends on ur business case.
here is an example where an access code is needed:
in case u have many sites each with its own site code, and for example From site x, merely dialing the combination of site y's code with the desired extension for example (11234) would partially overlap with site x's extension (1123), thus causing interdigit timeout issues. to overcom this interdigit time out,u can assign 8 as an inter-site on-net access code, this would allow site x to dial 81234 to reach site y's extension 1234 without overlapping problem
hth
please remember to rate helpful posts
/majdi
