06-19-2007 07:57 AM - edited 03-03-2019 05:30 PM
Does anyone know a good tool that shows the full traffic path? I am wanting someting that shows traffic from PC to Switch to Router to Router to Router to Switch to End device. Your help is appreciated.
06-19-2007 08:06 AM
I do not know of any specific tool that does this, however use the generic Trace Route command or try the Microsoft Path Ping command. These will give you Layer 3 results but not Layer 2 results. You will not see any switches (layer 2) that your traffic is going through unless it is set for Layer 3...Good Luck..Please rate...
06-20-2007 04:55 AM
look for an app called packet tracer.
