Richard Burts Tue, 06/19/2007 - 09:24
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Bar
Here is an example of configuring a router to act as a DHCP server.
First you may want to exclude addresses such as the router interface address:
ip dhcp excluded-address 172.18.80.97
then you configure the DHCP pool with the subnet of addresses that it should use:
ip dhcp pool example_pool
network 172.18.80.96 255.255.255.224
default-router 172.18.80.97
dns-server 172.18.128.33
domain-name your_domain.com
lease 3
Rick
visteknetworking Tue, 06/19/2007 - 10:12
Hi Rick,
Thank you for your reply.
How can I check if there any clients are getting ip
