ACS SE Initial Installation
Jun 19th, 2007
I'm having some trouble with the initial console connection into a Cisco 1113 Secure Access Control Server(brand new out of box). I've followed the docs to configure my emulation software but I'm still not having any luck. I'm just wondering if there are any known "gotchas" when consoling in for the first time to one of these appliances. I have verified that my software and cables work by consoling into another router. My current emulation settings are below:
baud = 115200
databits = 8
parity = N
stops = 1
flow control = none
emulation type = ansi
I get nothing when using these values.
Any help will be much appreciated.
shivlu jain Sat, 07/07/2007 - 04:46
Got to HypTer file menu click on Property go to settings click on ASCII setup
click the check box
1 send line ends with line feeds
2. echo typep characters locally
jkl1972 Sat, 07/07/2007 - 16:09
The issue has been resolved. Thank you for the reply.
