WAAS NM Enterprise vs. Transport License
Jun 19th, 2007
Hi all,
I am evaluating the WAAS Network Modules for the 2811 routers and it is not very clear to me the difference between the Transport License and the Enterprise License.
Can I do CIFS optimization and file caching with the transport license or do I need the Enterprise license?
Does anyone has some documentation that explains more clearly the difference between the two licenses?
Syed Iftekhar Ahmed Wed, 06/13/2007 - 14:00
Transport license includes the layer 4 transport optimizations (TFO, DRE, Compression ...). The Enterprise license includes all the Layer 4 optimizations plus the layer 7 "application adapters" such as the file/print protocol optimizations.
If you want to run a CIFS environment and
wants prepositioning and print services, then the Enterprise license (which includes WAFS) is required on all "Edge/Core" WAEs.
Syed Iftekhar Ahmed
Zach Seils Fri, 06/22/2007 - 16:27
Also note that the NME-WAE-302 only supports the transport license.
siddiqui75 Sat, 06/23/2007 - 23:56
DO WAE-512-K9 AND WAE-612-K9 comes with transport and enterprise license or is it required to get the enterprise license seperately.
Zach Seils Mon, 06/25/2007 - 17:57
The software licenses are purchased separately for WAAS, regardless of the hardware platform used.
