FWSM 3.1(3)
Jun 19th, 2007
Trying to pass traffic thro a FWSM and I don't seem to be getting anywhere. if someone knows how to, that would help a lot. Sample config below..
System Config >>
context Lab
allocate-interface vlan101
allocate-interface vlan201
config-url dis:/admin.cfg
member default
Context Lab
firewall transparent
interface vlan101
nameif outside
security-level 0
bridge-group 1
interface vlan201
nameif inside
security-level 100
bridge-group 1
interface bvi 1
ip address / 24
Have a routed interface on vlan 201 connecting to port 1/5 and a routed interface on vlan 101 connecting to port 1/10 on the switch. Trying to PING from the FWSM to vlan 201 & vlan 101. I get no replies for both PINGs. Pls advise.
carenas123 Mon, 06/25/2007 - 11:45
In routed mode, some types of traffic cannot pass through the FWSM even if you allow it in an access list. The transparent firewall, however, can pass most types of traffic through using either an extended access list (for IP traffic) or an EtherType access list (for non-IP traffic).
The transparent mode FWSM does not pass CDP packets, or any packets that do not have a valid EtherType greater than or equal to 0x600. For example, you cannot pass IS-IS packets. An exception is made for BPDUs, which are supported
