Cisco 857w ADSL2+ connection speed
Answered Question
Jun 19th, 2007
I need to see the actual connection speed on which the link is established on cisco 857w ADSL2+ router.
Can anyone help with the related commands or point me where i can find it in cisco SDM?
Muhammad
Correct Answer by paolo bevilacqua about 10 years 1 week ago
Not sure about the SDM. Telnet into the router and do "show dsl interface" You will see speed information and more.
Overall Rating: 4 (1 ratings)
Correct Answer
paolo bevilacqua Tue, 06/19/2007 - 14:02
  • Hall of Fame,
    Founding Member
falain Fri, 06/22/2007 - 12:11
hi,
try "show dsl int atm 0"
and you can enable train buffer log with:
"int atm 0
dsl enable-train"
hopes it helps
