WAE disk_check.sh and disk_clean.pl
Answered Question
Jun 19th, 2007
I ran the disk_chck.sh script on a WAE and disk_status.txt says 'device /dev/md2 (/state) is File system errors were detected. <snip>'. The readme for disk_clean.pl says 'Although the device is on the network, it will be offline in the CM GUI. Deleting the partitions also deleted the CMS database on this device, so you will need to delete the device on the CM, then re-enable the commands on the CLI of the device.'
What 're-enable' commands? I should execute this on the CLI of which device (WAE or CM)?
Correct Answer by Gregory Scarlett about 9 years 4 months ago
The procedure at the following URL should get everything back up and running after the disk clean script has been run.
Hope this helps.
Greg Scarlett
Overall Rating: 5 (1 ratings)
