Can't copy runn to start
Answered Question
Jun 19th, 2007
We have a 3750 switch that's stack. When I try to do a wr mem I get the following error. Is their a solution for this?
thanks Cisco
on199b47zas03#wr memory
Building configuration...
Error writing new config file "flash:/config.text.new"
Error writing new config file "flash:/private-config.text.new"[OK]
on199b47zas03#
on199b47zas03#show env stack
SWITCH: 1
FAN is OK
TEMPERATURE is OK
POWER is OK
RPS is AVAILABLE
SWITCH: 2
FAN is OK
TEMPERATURE is OK
POWER is OK
RPS is AVAILABLE
on199b47zas03#
on199b47zas03#show flash
Directory of flash:/
2 -rwx 7140535 Feb 28 1993 22:18:49 -05:00 c3750-ipbasek9-mz.122-25.SEE.bin
3 -rwx 796 Nov 3 2006 13:19:56 -05:00 vlan.dat
4 -rwx 34436 Nov 11 2006 19:09:06 -05:00 config.text
5 drwx 192 Feb 28 1993 19:06:07 -05:00 c3750-ipbase-mz.122-25.SEE1
458 -rwx 33280 Jun 19 2007 20:30:22 -04:00 config.text.new
15998976 bytes total (0 bytes free)
on199b47zas03#
Since this is stacked, would it have to copy it on both flash? Do we have to specify the full path?
on199b47zas03#show flash1:
on199b47zas03#show flash2:
Directory of flash2:/
2 -rwx 7140535 Feb 28 1993 22:30:09 -05:00 c3750-ipbasek9-mz.122-25.SEE.bin
3 -rwx 34436 Nov 11 2006 19:09:11 -05:00 config.text
4 -rwx 1954 Nov 11 2006 19:09:11 -05:00 private-config.text
5 drwx 192 Feb 28 1993 19:06:11 -05:00 c3750-ipbase-mz.122-25.SEE1
458 -rwx 796 Nov 6 2006 19:22:46 -05:00 vlan.dat
15998976 bytes total (31232 bytes free)
on199b47zas03#
Correct Answer by glen.grant about 9 years 10 months ago
If its stacked using the stack cables in the back it automatically gets saved to any switch in the stack with the stackmaster being the main switch . I'll assume that doing a "copy run start" command gives you the same error . Oh see the problem you have zero space left in flash1: so it can't save the config , get rid of the image file you are not using and try again . You have little space left in flash 2: either so do the same thing there.
Overall Rating: 4.5 (2 ratings)
Correct Answer
glen.grant Tue, 06/19/2007 - 16:46
  • Purple, 4500 points or more
dundeenit Thu, 07/26/2007 - 23:41
The answers in your post ;0)
-->0 bytes free
The oldest code on the switch seems to be c3750-ipbasek9-mz.122-25.SEE.bin so I would delete that and then perform the write mem.
But do a show version and check for the code that you are using first, and delete the one that is just taking up space.
On stacked switches, the config is automatically copied to all switches when you write the changes.
George.
