Booting switch - Error loading
Jun 19th, 2007
I have a used 2950 switch and when it boots I get a prompt that says 'switch:' and there's very few commands available. It appears that it might not have an IOS? I tried typing boot and this is the output:
switch: boot
Loading "flash:c2950-i6q4l2-mz.121-13.EA1c.bin"...flash:c2950-i6q4l2-mz.121-13.E
A1c.bin: no such file or directory
Error loading "flash:c2950-i6q4l2-mz.121-13.EA1c.bin"
Interrupt within 5 seconds to abort boot process.
Boot process failed...
Overall Rating: 5 (1 ratings)
guruprasadr Tue, 06/19/2007 - 22:50
  • Gold, 750 points or more
HI, [PLS RATE if HELPS]
The below LINK will Fix your Problem:
http://www.cisco.com/en/US/products/hw/switches/ps628/products_tech_note09186a0080169696.shtml
Please Check below:
1.The switch: prompt indicates that the switch has not booted completely and requires the user to complete the boot process.
2. The error loading flash: message indicates that the switch failed to load an image because of a corrupt or missing image.
The corrupt or missing image can be the result of a failed download. In this case, the image has a bad checksum or a failed software upgrade, and the upgrade procedure was not followed properly. There is the possibility that the user deleted the image but did not replace the image. A boot variable can have been set incorrectly.
With a console session open, you see an error message that is similar to this:
Error loading "flash:c2950-i6q4l2-mz.121-12c.EA1.bin"Normally, the switch attempts to automatically boot the next valid image in the Flash file system. Here is an example:
3.If there is no valid backup image from which to boot, the boot process fails completely. Here is an example:
Verify the above Link for Step-by-Step Recovery Procedure.
PLS RATE if HELPS
Best Regards,
Guru Prasad R
rileymartin Thu, 06/21/2007 - 05:17
Thanks! That's exactly the information that I needed. As it turned out there was no image file in the flash. I was able to transfer one using hyperterminal and now it's up and running. Thanks again for you help.
