Numbering Plan change.
Jun 19th, 2007
We are planning to change the numbering plan of our CCM cluster. Currently the numbering plan was based on the employee number which is 4 digits. We are planning to change it to six digits. We are having three locations.
Location A will be having 1XXXXX
Locaton B will be having 2XXXXX
System relaated numbers like meetme voice mail will be in the range 8xxxxx.
What is the best way to do this change. following is my plan;
1: take a backup of existing CCM
2: Delete all the phones using BAT
3. Upload the New details using BAT
4. Test the functionality after upload.
Please let me know if it is correct.
Krishna.
Anonymous (not verified) Mon, 06/25/2007 - 14:22
The values for route filter tag fields can contain the wildcard characters X, *, #, [, ], -, ^, and the numbers 0 through 9.
chips1999 Thu, 05/24/2012 - 08:19
I'm about to go through a similar process,did you have any luck with the procedure?
