MDS 9020 Log Files
Jun 19th, 2007
Have had a bad SFP creating errors, and log entries. Problem is that when log is full, the switch re-boots. Does anyone know if I can clear the log out of old messages.
hadbou Mon, 06/25/2007 - 14:24
Periodically check how full the /dev/shm is using the following command
Device # *sh system internal flash | inc shm*
none 102400 5744 96656 6% /dev/shm
2. If you see that the %-used keeps on increasing then you need to find
out which files(s) in /dev/shm is causing this. There is no CLI command for
this. One has to load debug plugin and check file sizes in /dev/shm using "ls"
Additionally you can run "system pss shrink" command to compact the pss
files to make some more room /dev/shm.
Trending Topics: Storage Networking
