What is the consideration about SSL when upgrading CSS software
Jun 19th, 2007
  • Bronze, 100 points or more
Hi everyone,
I plan to upgrade CSS software from 07.30.1.06 to 07.50.3.03. The SSL module is installed in this CSS and CSS uses certificate from CA for user authentication.
So I would like to know what the answer for the following two question are.
First question:
1: After upgrading software, do I need to re-issue the certificate from CA and then generate private key ?
and/or
2: Can I backup existing certificate and private key to re-use/import after upgrading software ? that means I do not need to re-issue the certificate from CA.
and/or
3: Is the certificate maintained on CSS disk even after upgrading software ? that means I do not need to re-issue the certificate from CA and also backup certificate.
Second question:
This CSS is configured to execute SSL keepalive to real servers. After upgrading software, Does CSS recognize that real servers are ALIVE automatically or do I need some manual operation to get CSS recognized real servers are ALIVE ?
Would you please let me know if you have any comment and any information.
Best regards,
Shinichi
Gregory Scarlett Wed, 06/20/2007 - 04:11
  • Cisco Employee,
Answer: No, the key and certificate will remain on the CSS.
Answer: If you want, you can export the Certificate and Key using the command "copy ssl export"
Second question:
Answer: As part of the upgrade process, the CSS will reboot. Once it comes back up, keepalives will automatically begin again without any intervention.
Hope this helps.
Greg Scarlett
APAC TAC
