Cisco 7204VXR router with BRI interfaces
Jun 19th, 2007
Dear Sir,
i have a 7204VXR router with 7200-NBE-G2 engine, and i want to install BRI interfaces on it, i searched the cisco site and found the PA-8B-ST module supported on the 7200 router, and when i worked on the cisco dynamic configuration tool the result error dectate that the NBE-G2 is not compatible with the PA-8B-ST, so how i can install BRI interfaces in this router, please help me
Paolo Bevilacqua Wed, 06/20/2007 - 01:04
possibly cisco has dropped support for this card on the NPE-G2,due to the different roles (access Vs. edge). You should be able to support PRi however.
