hdlc ping problem
Jun 19th, 2007
hi guys
i have configure my router to hdlc
to cinnect to a remote router
bith side are hdlc
one side can ping its own serial address but i can not ping my own ip address or the remote ip address.
line protocol is also up on bith side
any idea please?
smothuku Tue, 06/19/2007 - 23:16
  • Silver, 250 points or more
Hi ,
R u pining from PC which is connected in LAN ...how are u doing the test....
Can you explain it clearly...
If you are trying from pc which is connected in LAN make sure that
1.gateway
2.ip assigned to PC are correct...
Can you paste the config of both the routers.
Satish
emadehsan Tue, 06/19/2007 - 23:30
hi
thank you for your reply
i am ping from the router inside
here is the sho interface:
Serial2/0:23 is up, line protocol is up
Hardware is DSX1
Internet address is 172.16.0.30/30
MTU 1500 bytes, BW 128 Kbit, DLY 20000 usec,
Encapsulation HDLC, loopback not set
Keepalive not set
Last input never, output 00:00:20, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 14
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/1/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 96 kilobits/sec
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
286 packets output, 18370 bytes, 0 underruns
0 output errors, 0 collisions, 4 interface resets
0 carrier transitions
Timeslot(s) Used:24-25, Transmitter delay is 0 flags
Richard Burts Wed, 06/20/2007 - 05:30
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
ehsan
I am guessing that there is a mismatch between the routers in their addressing - perhaps a mismatch of subnet mask. I see that this router uses a /30 mask. Is it possible that the router on the other end of the connection is using a different mask (or perhaps a different address)?
Rick
