modem dialin problem
Jun 20th, 2007
Hope you can help me with this, Im stuck.
I have a 2500 router with several external modems (US Robotics 56k) connected over asynch cables. the line config is setup to autocommand telnet to a backend server.
When I attempt to dial in, whichever modem answers, it seems to pick up the call, but then it drops almost immediately. The router log shows the same debug message each time:
Jun 18 14:40:20.691: tty1: Modem: HANGUP->IDLE
Jun 18 14:40:22.031: TTY1: Line reset by "Virtual Exec"
Jun 18 14:40:22.031: TTY1: Modem: IDLE->HANGUP
Jun 18 14:40:22.035: TTY1: destroy timer type 0
Jun 18 14:40:22.035: TTY1: destroy timer type 1
Jun 18 14:40:22.039: TTY1: destroy timer type 3
Jun 18 14:40:22.039: TTY1: destroy timer type 4
Jun 18 14:40:22.039: TTY1: destroy timer type 2
Jun 18 14:40:22.727: TTY1: dropping DTR, hanging up
Jun 18 14:40:22.727: tty1: Modem: HANGUP->IDLE
Jun 18 14:40:24.764: TTY1: restoring DTR
Jun 18 14:41:48.646: TTY1: Line reset by "Virtual Exec"
router config:
version 12.0
service password-encryption
hostname R1
logging buffered 50000 debugging
aaa new-model
aaa authentication login default local
aaa authentication login no_user enable
aaa authentication login noaut none
aaa authentication login noprompt none
enable secret 5 <removed>
username test password 7 <removed>
ip subnet-zero
clock timezone GMT 0
interface Ethernet0
ip address x.x.x.x 255.255.255.0
no ip directed-broadcast
no ip mroute-cache
interface Serial0
no ip address
no ip mroute-cache
shutdown
no fair-queue
interface Serial1
no ip address
no ip mroute-cache
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 x.x.x.x
line con 0
transport input none
line 1
no exec-banner
exec-timeout 0 0
no activation-character
autoselect during-login
session-limit 1
no vacant-message
login authentication noaut
modem Dialin
autocommand telnet x.x.x.x 3001 /noecho
terminal-type edit
exec-character-bits 8
special-character-bits 8
transport preferred telnet
transport input all
escape-character BREAK
stopbits 1
flowcontrol hardware
line 2
no exec-banner
exec-timeout 0 0
session-limit 1
no vacant-message
modem Dialin
autocommand telnet x.x.x.x 3000 /noecho
terminal-type edit
transport input all
telnet transparent
stopbits 1
line aux 0
login authentication no_user
line vty 0 4
end
Wilson Samuel Wed, 06/20/2007 - 11:51
  • Gold, 750 points or more
  • Community Spotlight Award,
    Mobile User, July 2015
On a similar occassion wherein I was trying to get Aux Port configured for Remote Dialin (for exec access and not for data) I tried almost 4 USR modems and everytime all the modems would get stuck at the handshake and never be able to complete the process.
However when I changed the modem to a simple make and model, it did work!
I guess its a problem with USR, have you ever tried with some other brand?
Kind Regards,
Wilson Samuel
sundar.palaniappan Wed, 06/20/2007 - 16:59
  • Green, 3000 points or more
It may be a problem with the dip switch setting in your USR modem.
Try setting dip switches 1, 3 & 8 down and other ones up or 3, 7 & 8 down and others up. I have used one of this settings effectively in the past.
Let us know if that helps.
Sundar
spyoung Wed, 06/20/2007 - 23:21
Unfortunately this modem (USR 56k fax modem) seems to have no dip switches, not externally anyway. Unless there are dip switches inside the case on the main circuit board.
I will source another modem and try that.
thanks,
