MIMIX port for Cisco WAE
Zach Seils Fri, 06/22/2007 - 21:46
Afdllah,
Are you using Cisco WAAS? If so, can you please provide some additional information on how you are performing interception?
Zach
afdil Sun, 07/01/2007 - 20:24
Yes, I used Cisco WAAS version 4.0.9,
i configure WCCP on both switch catalyst on interface vlan :
ip wccp 61
ip wccp 62
int vlan888
ip wccp 61 redirect out
ip wccp 62 redirect in
on interface to WAE ;
ip wccp redirect exclude in
regards
afdil
iwanc Wed, 07/11/2007 - 20:36
Zach,
Have you ever try WAAS to accelerate MIMIX traffic? Could you share your configuration?
Iwan
Zach Seils Thu, 07/12/2007 - 06:33
Iwan,
I have not personally used WAAS to accelerate MIMIX traffic.
Zach
iwanc Fri, 07/13/2007 - 00:15
Hi Zach,
But, do you have any documentation that mention WAAS able to accelerate MIMIX traffic or user guide about it? Because I cannot find it on cisco website and I am afraid that Cisco WAAS is unable to accelerate MIMIX.
Iwan
Zach Seils Fri, 07/13/2007 - 20:59
Ivan,
I checked internally, but was unable to find any references for WAAS optimizing MIMIX traffic. However, this doesn't mean that it isn't possible. Have you tried? Do you know the TCP ports being used?
Zach
iwanc Sun, 07/15/2007 - 22:43
Zach,
I have tried it with several scenario. First, using default WAAS policy. Second, create new policy using destination and source port from 1000-65000. Both scenario give no result. I have no idea the exact TCP port for MIMIX.
Iwan
afdil Mon, 07/16/2007 - 19:33
zach,
when i'm doing POC to optimize MIMIX,
i use command :
#show tfo connection summary
and output of this command :
Local-IP:Port Remote-IP:Port Conn Type
10.204.230.2:50007 10.204.229.2:56028 PT In Progress
10.204.229.2:56028 10.254.20.11:50007 PT In Progress
ip add 10.204.230.2 is MIMIX server in DC
ip add 10.204.229.2 is MIMIX server in DRC
i already used that port to optimize MIMIX,
but still not optimize
Zach Seils Wed, 07/18/2007 - 07:17
AFDILAH,
You can use the debug command:
debug tfo conn auto
to determine why the connection is going into pass-through.
Zach
iwanc Thu, 07/19/2007 - 23:12
Thank Zach, we will try it. But unfortunately, we cannot do it soon. We need time to setup the lab.
Thanks.
