TFTP Server
Answered Question
Jun 20th, 2007
Can someone recommend a good TFTP server - one that can handle IOS versions upto a 100 MB.... (even a paid one)
Correct Answer by Richard Burts about 9 years 9 months ago
Sunil
I have heard good things about tftpd32 and its ability to handle large files, though I do not know if it does 100 MB. You can find information here:
http://tftpd32.jounin.net/
I frequently use 3cdaemon for TFTP and for FTP and have had good success with it. You can find it here:
http://support.3com.com/software/utilities_for_windows_32_bit.htm
Rick
Overall Rating: 4.5 (2 ratings)
Joe Clarke Wed, 06/20/2007 - 08:15
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You didn't mention an OS, but the standard TFTP that comes with FreeBSD is fully RFC compliant, and supports arbitrarily large files. There is also a good Open Source TFTP server called tftp-hpa (ftp://ftp.kernel.org/pub/software/network/tftp/) which can also handle large files.
srego4 Wed, 06/20/2007 - 08:17
yes I forgot to mention OS.... For Microsoft Win XP.
Correct Answer
Richard Burts Wed, 06/20/2007 - 08:16
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Sunil
Rick
srego4 Wed, 06/20/2007 - 08:37
HI Rick,
The 3CD had limits on file sizes... it stops at abt 30 MB, but the tftpd32 worked well - I managed 80 MB .. so this one looks good. Thanks again.
Richard Burts Wed, 06/20/2007 - 09:17
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Sunil
I am glad that my response was helpful. Thank you for using the rating system to indicate that your questin was resolved (and thanks for the rating). It makes the forum more useful when people can read a question and can know that they will read an answer that resolves the question. I encourage you to continue your participation in the forum.
Rick
