Mobility Manager 1.2(4) and CCM 5.1 shared line link, outgoing port
Answered Question
Jun 20th, 2007
I ve created the 2 user and cti pool, the rp but the root point still not Oregisterd on the CCM. And on the mobility the two links are Out Of Service.
Any idea about this ?
Correct Answer by Marcos Assakawa about 9 years 9 months ago
Can you enable the JTAPI auto update, so you will have the correct JTAPI version working with CCM 5.1.
Overall Rating: 5 (1 ratings)
thisisshanky Wed, 06/20/2007 - 06:13
  • Purple, 4500 points or more
Have you associated the cti ports with the mm_shared/mm_out user (dont remember which user - please check the documentation) ? Try restarting CTI manager service on CM server and Mobility manager service from MM server.
ntherond Wed, 06/20/2007 - 06:19
We have associated one user with the RP and the shared line and another user with the cti outgoing. We ve restarted MM and CCM, but the RP is not registered.
Correct Answer
Marcos Assakawa Fri, 06/22/2007 - 21:40
  • Cisco Employee,
thisisshanky Sat, 06/23/2007 - 08:33
Good catch Marcos, That is something that was told by TAC to set me when i had similar issues.
ntherond Sun, 06/24/2007 - 08:44
Hi thanks fo your reply,
Could you explain me what i should enable fo the jtapi. Is there something about this in the documentation.
Nicolas
thisisshanky Sun, 06/24/2007 - 20:05
This setting can be fiound under Mobility manager system parameters.
ntherond Thu, 06/28/2007 - 05:30
Thanks a lot, I ve enabled the jtapi autoupdate, and the links comes up!!
Nicolas
