Jun 20th, 2007
Can I install WCS and ACS in the same machine and run them at the same time
Overall Rating: 4 (2 ratings)
Jagdeep Gambhir Wed, 06/20/2007 - 07:26
Hi ,
This configuration is not recommended because of shared common ports used by both service. There are a lot of hidden port values that can not be modified. I've tested this personally and having WCS and ACS on the same box is not a reliable setup.
Note : If that helps then please mark it resolved so that other can benefit.
diro Thu, 06/21/2007 - 09:28
i'm running wcs 4.1 and acs 4.0 on the same windows 2003 server for the cuwn course without any problem. Knowing that cisco required this as a lab setup, i can't believe their will be port problems.
diro Mon, 07/02/2007 - 10:07
I'm running the free vmware server on a shuttle PC (SN27P2) athlon based (AMD Athlon 64 X2 socket AM2 3800+) with 4GB of ram however the vitual machine only gets 1GB of ram. And is only using 1 processor.
elkono200 Fri, 06/22/2007 - 23:59
i'm using Windows 2003 Server with WCS and ACs on the same machine... without any problems...
