Forwarding TCP Ports on the same LAN
Hi all, I wish to forward a TCP port # request from an internal ethernet port to an external wan port on a 2800 router. For example we wish to forward any request on port 5632 on the LAN ether network port which is 192.100.100.254 to another device which is on the same network IP address 192.100.100.42. Can you please advsie if this is possiable without using NAT inside/outside rules. Thanks
