Unable to Remove Metal Casing for Cisco 1924 Switch
Jun 20th, 2007
Hi Guys,
I just bought a Cisco 1924 switch and would like to check out its insides but I can't seem to work out how to remove the metal cover.
I have removed all the visable screws and have also checked out the Cisco Support site and Internet but considering that the 1924 switch is an end of line product, I'm finding it extremely to find any support resources for the 1924 switch.
I don't really want to force it open as I don't want to crack or snap anything.
Thanks all
two5om
mohammedmahmoud Wed, 06/20/2007 - 05:43
Hey Steven,
No extra work, just remove all the visible screws and then try to smoothly slide the metal cover, its is most probably just stuck, try gently freeing it.
HTH,
Mohammed Mahmoud.
Steven-Edouard Wed, 06/20/2007 - 06:14
Hi Mohammed,
Still haven't had any luck.
Really tough to remove that cover.
Tried to wedge a screw driver in the gaps to try and loosen it a little but it still won't budge. :(
Very stubborn.
I was hoping that Cisco would have had some sort of a guide for eg: "Upgrading hardware for 1900 Switches" but I found nothing.
Steve
