ssh transfer of arp access-list to 3750 hang up
Answered Question
Jun 20th, 2007
I need configure remotely i.a. the list about 462 lines (2 not full "c-class" IP scopes)
on the 3570 switch . Ssh protocoll transfers shorter lists well.
Transfer a longer list stops usually after the 375th line. Ssh connection
remains hung up in the idle state.
Transfer of the same list via telnet (copy-paste into the telnet window)
is always successful. But i'm afraid ssh is obligatory in this case.
One more thing : Transfer a longer list via ssh to unburdened switch is
always successful too. Any overburdening issue?
Could somebody give me a solution or workaround?
Switch used:
Cisco IOS Software, C3750 Software (C3750-IPBASEK9-M), Version 12.2(25)SEE2, RELEASE SOFTWARE (fc1)
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.1(14r)EA1a, RELEASE SOFTWARE (fc1)
cisco WS-C3750G-24TS (PowerPC405) processor (revision D0) with 118784K/12280K bytes of memory.
Processor board ID CAT0817N0UH
Last reset from power-on
9 Virtual Ethernet interfaces
56 Gigabit Ethernet interfaces
Motherboard assembly number : 73-7058-10
Power supply part number : 341-0045-01
Motherboard serial number : CAT0816158H
Power supply serial number : LIT081204B8
Model revision number : D0
Motherboard revision number : A0
Model number : WS-C3750G-24TS-S
System serial number : CAT0817N0UH
Hardware Board Revision Number : 0x09
Correct Answer by glen.grant about 10 years 1 month ago
Can't you just tftp it from a server ? USe the following.
Use the copy {ftp: | rcp: | tftp:} system:running-config command to load a configuration file from a network server to the router's running configuration. The configuration will be added to the running configuration as if the commands were typed in the command line interface. Thus, the resulting configuration will be a combination of the previous running configuration and the loaded configuration file, with the loaded configuration file having precedence.
Overall Rating: 4.3 (4 ratings)
leighharrison Wed, 06/20/2007 - 07:04
  • Gold, 750 points or more
This depends on what SSH client you are using.
The easiest thing to do would be to paste it in 200 lines at a time.
LH
** Please rate all posts **
t.fiala Wed, 06/20/2007 - 07:31
Thanks Leigh.
I am sorry, I did not describe my problem in detail. Lists are generated from the database and transferred automatically at each modification using OpenSSH library from a PHP script. The number "375 lines" refers to this method. The ssh clients in MS Windows (PuTTy, Teraterm) can not be used at all. They stops after 10 lines approx. (And are not suitable for automated transfer.) TF
leighharrison Thu, 06/21/2007 - 00:03
Hi there,
Rather than have openssh log in and paste the lines, have you considered tftp'ing the new config to running-config?
LH
t.fiala Thu, 06/21/2007 - 05:28
Hi Leigh,
we will consider all possible methods. I would like to load the smallest necessary parts of configuration only. Your suggestion has the disadvantage we would have to keep the whole actual configuration outside the switch. I suppose there should be a more convenient solution. The more or less constant number of lines transferred successfully seems to be highly suspicious. One more thing: lists are usually loaded successfully inside a LAN , hang up occures at a greater distance only ( 7 hops Gigabit Ethernet routers). TF
leighharrison Thu, 06/21/2007 - 05:52
Hi there,
You should be able to upload small bits of config to the router/switch via tftp on problems.
Give it a try!
LH
Correct Answer
glen.grant Thu, 06/21/2007 - 05:52
  • Purple, 4500 points or more
t.fiala Thu, 06/21/2007 - 06:56
Thanks Glen,
it is what I was seeking for. Works perfectly.
Tomas
t.fiala Thu, 08/30/2007 - 01:53
Hi Glen,
I've used ftp transfer, but transfer rate is
82 bytes/sec. Is it OK? The time needed for
transfer the largest list is about 5 minutes, it is nearly unusable. Do you have an advice
how to speed up the tranfer?
Tomas
cs-a2p1#[ Kerberos V5 accepted forwarded credentials ]
copy ftp://www:web102@147.231.126.9/arp_070829_085413_200.txt test
Destination filename [test]?
Accessing ftp://www:web102@147.231.126.9/arp_070829_085413_200.txt...
Loading arp_070829_085413_200.txt !!!!!
[OK - 24572/4096 bytes]
24572 bytes copied in 300.563 secs (82 bytes/sec)
cs-a2p1#
