CSM3.02 CTMJrmServer: doesn't start
Jun 20th, 2007
hi to all!
I installed CSM 3.0.2
I've got RME update from 4.0.3 to 4.0.5
before this I made an automatic bake-up.
After restore it JRM daemon didn't start
it gives me this error:
CTMJrmServer: initializing daemon manager
CTMJrmServer: initialized daemon manager
getJRM: SUCCESSFUL CONNECTION TO JRM.
com.cisco.nm.xms.ctm.common.CTMException: CTMServer::publish Cannot publish URN: ""JRM"". Reason : Registry Server did not respond
at com.cisco.nm.xms.ctm.server.CTMServer.publish(CTMServer.java:235)
at com.cisco.nm.xms.ctm.server.CTMServer.publish(CTMServer.java:182)
at com.cisco.nm.rmeng.jrmwrapper.server.CTMJobManagerServer.<init>(CTMJobManagerServer.java:69)
at com.cisco.nm.rmeng.jrmwrapper.server.CTMJobManagerServer.main(CTMJobManagerServer.java:34)
at com.cisco.nm.rmeng.util.logger.ServiceLogLevelChanger.notifyLevelChange(ServiceLogLevelChanger.java:41)
at com.cisco.nm.rmeng.util.logger.ServiceLogLevelChanger.notifyLevelChange(ServiceLogLevelChanger.java:61)
at com.cisco.nm.rmeng.jrmwrapper.server.CTMJobManagerServer.<init>(CTMJobManagerServer.java:56)
[ mer giu 20 16:29:42 CEST 2007 ],INFO ,[main],com.cisco.nm.rmeng.jrmwrapper.server.JobManagerExt,getJRM,117,getJRM: bind successful
[ mer giu 20 16:29:48 CEST 2007 ],INFO ,[main],com.cisco.nm.rmeng.jrmwrapper.server.JobManagerExt,getJRM,251,getJRM: SUCCESSFUL CONNECTION TO JRM.
thanks for any helps
Leonardo
Joe Clarke Wed, 06/20/2007 - 08:06
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Did the restored data come from a different host, or have a different hostname associated with it? Did you aforementioned LiaisonServlet problems start after this restore?
Leonardo Roberto Wed, 06/20/2007 - 11:55
well... I have had a problem with liason servlet before this error.
So... I update the CSM 3.01 to 3.02.
no more liason servlet problem I have encounterd.
During, CSM 3.02 installation I answered yes to the automatic backup.
After the installation was completed.. I made a restore backup of automatic-backup directory.
after that RME has given that error.
The restore is made from the same host, but...
I tried to retore backup from a daily scheduled backup directory first. I don't remember what's happened... but maybe it was failed.
So... do you think I have to reinstall CSM 3.01? CSM 3.0.2 is more stable of CSM3.0.1?
Joe, I can reload devices manually, I didn't need to restore backup now.
I need to have a stable CSM.
CSM 3.0.1 was patched with all patchs found in download software. I have 200 devices license software for CSM 3.0.1. Can I upgrade to CSM 3.1 with the same license, or I have to purchase this one?
This case is critical because in this week we have the trial.
hope your helps.
Leonardo
Joe Clarke Wed, 06/20/2007 - 11:59
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
CTMJrmServer is specific to RME. I suggest if you have critical CSM questions, you take those up on one of the security forums, or open a TAC Service Request.
To debug the CTMJrmServer problem, the jrm.log and CTMJrmServer.log would be useful to see.
