Bulk Import when Customer has Unified Messaging
Answered Question
Jun 20th, 2007
I just want to see what the easyest way to import 500 users when a customer has an existing Unified Messaging VM and the users are already created in AD and Exchange, they only need to have VM accounts setup.
Please verify id I only need to use .csv file with the following parameters:
ALIAS, DTMF_ACCESS_ID
Correct Answer by ranpierce about 9 years 7 months ago
No there are at least 3 and you really should use 4
read this section carefully.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/402/administration/guide/ex/SAG_0160.html#wp1184079
rlp
Overall Rating: 5 (1 ratings)
ranpierce Wed, 06/20/2007 - 09:25
Be happy to help.
You are correct these are the minimum 3 fields needed for bulk import to work. Just remember the subscriber are going to be created with the default template.
One other thing. I am not cleare as to the existiong UM VM and needing to set up VM accounts. Do you mean the AD and Exchange accounts are set up and you only need to import?
rlp
ranpierce Wed, 06/20/2007 - 09:35
I was wrong, didn't read your post clearly. I am looking up the correct fields now.
tony.hanson Wed, 06/20/2007 - 09:38
Yes, I only need to import the users, they are already setup in AD and Exchange. You said that there are 3 fields minimum, Could you please let me know those three, I thought only two, ALIAS and DTMF_ACCESS_ID
ranpierce Wed, 06/20/2007 - 10:08
Since you do have the users in AD and exchange you do have to use all 4 fields. If not duplicate accounts might be created.
rlp
