2924XL and Encapsulation
Jun 20th, 2007
So we replaced a failed HP (sigh..should have had a Cisco in all along) switch with a backup Cisco 2924-XL. Performed basic config, and plugged it into our 2611 Router. Connection was just fine...THEN:
I went and enabled trunking/encapsulation on interface FastEthernet0/1 with the following (no errors):
switchport mode trunk
Our connection was fine until the above. Interface 0/0 on the router is also configured for encapsulation and now it seems the switch and router are not communicating.
When I bring it up in CNA, it shows the router as an "Unsupported Device". I downloaded and installed the latest image for this 2924XL and it installed fine...Image file: c2900xl-c3h2s-mz.120-5.WC17.bin
Any ideas? My gratitude ahead of time!
Overall Rating: 5 (2 ratings)
Edison Ortiz Wed, 06/20/2007 - 07:25
  • Hall of Fame,
    Founding Member
What's the configuration on the router ?
Is the router performing the inter-vlan routing ?
A sanitized config from the switch and router can expedite the troubleshooting process.
glen.grant Wed, 06/20/2007 - 13:52
  • Purple, 4500 points or more
CNA was developed well after the 2924 which is well past end of life so it wouldn't be supported. If you are trying to trunk you will have to supply the router config so we can look at it .
srberg5219 Thu, 06/21/2007 - 06:19
My apologies..Here is the Router config:
Current configuration : 1602 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname TestBench
enable secret xxx
ip subnet-zero
ip audit notify log
ip audit po max-events 100
call rsvp-sync
interface Ethernet0/0
no ip address
half-duplex
interface Ethernet0/0.1
description Main Interface Network
encapsulation dot1Q 1 native
ip address 192.168.220.254 255.255.255.0
interface Ethernet0/0.2
encapsulation dot1Q 2
ip address 192.168.2.254 255.255.255.0
interface Ethernet0/0.3
encapsulation dot1Q 3
ip address 192.168.1.254 255.255.255.0
interface Ethernet0/0.10
description Haase-Bench
encapsulation dot1Q 10
ip address 10.10.10.254 255.255.255.0
ip helper-address 192.168.220.10
interface Ethernet0/0.11
description Garry's Bench
encapsulation dot1Q 11
ip address 10.11.11.254 255.255.255.0
interface Ethernet0/0.12
description Tom's Bench
encapsulation dot1Q 12
ip address 10.12.12.254 255.255.255.0
interface Ethernet0/0.16
description Voip Network
encapsulation dot1Q 16
ip address 192.168.16.254 255.255.255.0
interface Ethernet0/1
no ip address
half-duplex
ip classless
ip route 0.0.0.0 0.0.x.x.168.220.253
ip http server
snmp-server community bench RO
snmp-server community public RO
snmp-server enable traps tty
snmp-server host 192.168.220.79 bench
dial-peer cor custom
line con 0
line aux 0
line vty 0 4
password xxx
login
end
Edison Ortiz Thu, 06/21/2007 - 06:23
  • Hall of Fame,
    Founding Member
Please post the show vlan and show run output from the switch.
srberg5219 Thu, 06/21/2007 - 06:37
Current configuration:
version 12.
no service pad
hostname xxx
enable secret xxx
ip subnet-zero
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface VLAN1
ip address 192.168.220.252 255.255.255.0
no ip directed-broadcast
no ip rou
ip default-gateway 192.168.220.254
snmp-server engineID local xxx
snmp-server community private RW
line con 0
transport input none
stopbits 1
line vty 0 4
password xxx
login
line vty 5 15
password
login
end
VLAN Name Status Ports
1 default active Fa0/2, Fa0/3, Fa0/4, Fa0/5,
Fa0/6, Fa0/7, Fa0/8, Fa0/9,
Fa0/10, Fa0/11, Fa0/12, Fa0/13,
Fa0/14, Fa0/15, Fa0/16, Fa0/17,
Fa0/18, Fa0/19, Fa0/20, Fa0/21,
Fa0/22, Fa0/23, Fa0/24
1002 fddi-default active
1003 token-ring-default active
1004 fddinet-default active
1005 trnet-default active
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
1 enet 100001 1500 - - - - - 0 0
1002 fddi 101002 1500 - - - - - 0 0
1003 tr 101003 1500 - - - - - 0 0
1004 fdnet 101004 1500 - - - ieee - 0 0
1005 trnet 101005 1500 - - - ibm - 0 0
Shawn2924XL#
Edison Ortiz Thu, 06/21/2007 - 06:47
  • Hall of Fame,
    Founding Member
You need to create all the VLANs running on the router at this switch as well.
VLAN 2,3,10,11 and 16
Once you do that, you can configure the port in the switch as dot1q trunk.
abdel_n Thu, 06/21/2007 - 07:04
- Create needed vlans on the switch.
- Make sure you have configured .1q encapsulation in both subinterfaces in the router.
- set the default gateway on each hosts with its corresponding router subinterface ip.
- Make sure you have successfuly configured trunk ports on the switch, trunk interfaces should not appear in the output of the 'sh vlan' command as associated to a particular vlan).
Good work!
Abdel
Richard Burts Thu, 06/21/2007 - 06:50
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Shawn
Your original post says that you did basic config on the switch and it was talking to the router ok. Then you configured trunking and connectivity was disrupted. I note that the router is configured to process 7 VLANs on the trunk port. Did your "basic config" include multiple VLANs?
Before you configured trunking interface Fa0/1 on the switch was an access port and was communicating with the router. What VLAN was it a member of? It would have been sending untagged frames (since it is an access port) and I assume that the router would have treated it as part of the native VLAN.
I agree with Edison that seeing the config from the switch would be helpful.
Rick
