VXWorks to IOS conversion Tool for 350 Bridges
Jun 20th, 2007
I have been unable to find any information as to whether or not the VXWorks conversion tool with work on 350 Bridges. Anyone have any idea? Thanks
jreekers Wed, 06/20/2007 - 08:33
Hi. Unfortunately, as far as 350's go, only a 350AP can be converted to IOS. A 350 Bridge or Work Group Bridge cannot be IOS. If your unit is a bridge or work group bridge then you will not be able to convert it, but there is no limitation regarding upgrading VxWorks to the latest version.
HTH,
-Joe
millsusaf Wed, 06/20/2007 - 09:45
Thank you for you input.
Also can a 350 AP be loaded with Bridge firmware to become a bridge?
Can a 350 non-root bridge communicate with a 1200 series root bridge?
Believe it or not I used to work with 350's.
; ) Thanks
jreekers Wed, 06/20/2007 - 12:01
Hi.
A BR350 will act like a Bridge AND an AP at the same time, but simply trying to load bridge software on an AP will not turn it into a bridge.
An AP1200 can communicate with a BR350, but no VLAN's are supported in this configuration.
HTH,
-Joe
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
