Blackberry and Unity.
Jun 20th, 2007
We have unity 4.05 UM and we also use blackberrys.I have noticed that if you delete a voicemail via option 3 on the phone the voicemail deletes from the inbox but when sync'ing up with the blackberry the voicemail stays.
Is this normal behaviour.I noticed that if you delete the voicemail via outlook and then sync the blackberry then the voicemail goes.
cheers
mark
shane.orr Mon, 04/21/2008 - 06:14
did you ever get this resolved or anyone have any advice. I just switched unity servers and running version 5 and having the same problem.
shane.orr Mon, 04/21/2008 - 08:08
nevermind, i found the setting in the Class of Service section talking about putting deleted voicemails in the deleted items folder and that did the trick.
