VLAN AND STRIPPING- HELP
Jun 20th, 2007
Interface GigabitEthernet1/46- 1/48 are fiber points coming in off my Fiber equipment.
INT GIG1/1- 1/4 are going back to my Layer 3 Swtich. The fiber company wants me to give each customer its own VLAN - I know what to do for the Fiber ports (1/46-1/48 is just keep adding Addtional Vlans IE: switchport trunk allowed vlan 84,85), But I don't want to use any more then port 1-4 back to my Layer 3)
As you see I have 1 Vlan Assgined to each port back to my Switch.- How do I change that?
show run
Building configuration...
Current configuration : 3644 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service compress-config
hostname AllopticSwitch
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
vtp domain ''
vtp mode transparent
--More-- !
power redundancy-mode redundant
no file verify auto
spanning-tree mode pvst
vlan access-map 64 74
action forward
vlan access-map 84 85
action forward
vlan internal allocation policy ascending
vlan 64-65,74-75,84-85
interface GigabitEthernet1/1
description
switchport access vlan 64
switchport mode access
--interface GigabitEthernet1/2
description
interface GigabitEthernet1/3
description
switchport access vlan 74
interface GigabitEthernet1/4
description
interface GigabitEthernet1/5
description
switchport access vlan 84
interface GigabitEthernet1/6
description
interface GigabitEthernet1/7
interface GigabitEthernet1/8
interface GigabitEthernet1/9
interface GigabitEthernet1/10
interface GigabitEthernet1/11
interface GigabitEthernet1/44
interface GigabitEthernet1/45
description Alloptics-1
switchport trunk allowed vlan 64
switchport mode trunk
interface GigabitEthernet1/46
description All
interface GigabitEthernet1/47
description All
switchport trunk allowed vlan 74
interface GigabitEthernet1/48
description City
interface Vlan1
ip address 192.168.25.1 255.255.255.0
interface Vlan64
description All-1
ip address 192.168.26.1 255.255.255.0
interface Vlan65
description All-2
ip address 192.168.27.1 255.255.255.0
interface Vlan74
interface Vlan75
interface Vlan84
description CityPlattsburgh
ip address 192.168.28.1 255.255.255.0
shutdown
interface Vlan100
no ip address
interface Vlan101
no ip address
shutdown
interface Vlan2000
no ip address
shutdown
interface Vlan2500
description OFFICETEST
no ip address
shutdown
ip http server
no ip http secure-server
--More--
royalblues Wed, 06/20/2007 - 11:26
You should be able to add vlans to the trunk connecting back to the layer 3 switch
switchport trunk allowed vlan add
HTH, rate if it does
Narayan
cozyk1515 Wed, 06/20/2007 - 11:38
I have a ticket in with Cisco and changed my config - they said it should work but no go
vlan 50-100
description All-1
switchport trunk allowed vlan 50-69
no cdp enable
description ALL-2
description All-3
switchport trunk allowed vlan 70-90
no cdp enable
description All-4
description
--More-- switchport access vlan 84
description
interface GigabitEthernet1/41
interface GigabitEthernet1/42
interface GigabitEthernet1/43
description All-1
description All-1
--More-- switchport trunk encapsulation dot1q
description All-2
description
interface Vlan1
Vlan 50 - 100 Added!!!
interface Vlan64
description All-1
interface Vlan74
interface Vlan84
description
shutdown
interface Vlan100
no ip address
interface Vlan101
no ip address
shutdown
interface Vlan2000
no ip address
shutdown
interface Vlan2500
no ip address
shutdown
--More-- !
ip http server
royalblues Wed, 06/20/2007 - 11:46
yes it should work. you need to allow the vlans on trunks on both sides.
Can you post a simple network diagram
Narayan
