upgrading IOS on a switch
Jun 20th, 2007
I have a switch I want to upgrade the IOS on, I have the IOS image downloaded, and a tftp server running on my PC: can anyone help me with the basic steps to do next in order to upgrade the IOS?
Jagdeep Gambhir Wed, 06/20/2007 - 07:43
  • Red, 2250 points or more
Here are the steps
switch#dir flash:
shows the contents of the directory
switch#delete flash:filename.bin
this will delete the old IOS file
switch#delete flash:html/*
this will delete the old HTML file
switch#dir flash:
Make sure that old image isn't there.
switch#config t
switch(config)#no ip http server
switch(config)#end
switch#archive tar /xtract tftp://server_ip_address/filename.tar flash:
this copies the new IOS file to the switch
switch#config t
switch(config)#boot system flash:filename.bin
sets the path from which switch will be booted next time
switch(config)#ip http server
switch(config)#end
switch#wr mem
makes the changes to the switch configuration permanent
switch#show boot
shows which file will be used to boot the switch next time
switch#reload
will restart the switch
dthaker71 Wed, 06/20/2007 - 22:22
please be specific which switch IOS u wnated to upgrade
you can use archieve commands for new swicth upgrade just search with this command on cisco.com and u will get entire reference on that.
ALL the Best
dthaker71 Tue, 05/06/2008 - 01:38
Pls. find the same
System image file is "disk2:c7200p-advsecurityk9-mz.124-15.T4.bin"
Rgds,
Dilip Thaker
Neeraj Arora Wed, 06/27/2007 - 07:22
  • Silver, 250 points or more
You can check the following link:
http://www.cisco.com/univercd/cc/td/doc/product/lan/c3550/12113ea1/3550scg/swiosfs.htm
It has all the information and steps for transfering IOS file as well as additionla info about handling the configs as well
Again you have to be little more specific about the IOS and which switch are you using
One more useful link for IOS upgrade on Cat3550:
http://www.cisco.com/warp/public/473/190.html
Hope it helps
Neeraj
Pravin Phadte Wed, 05/21/2008 - 02:45
if you have the tftp server as ur pc you should be able to ping your pc from the router.
Also the tftp ports (69) should be allowed and should not be blocked by ACL.
from the switch prompt type
copy tftp: flash:
It will ask you for the file name and the tftp ip address.
provide the full filename with .bin and the ip address of tftp.
should be done.
This might erase your previous ios image on the flash. If it does not u need to change the boot seq on for the switch to boot with the new ios or just del the old ios.
