Gateway plis
Jun 20th, 2007
hi there..
i am trying to find a gateway with port E1..can us help me.
rob.huffman Wed, 06/20/2007 - 08:13
Hi JE,
Please excuse me if I am on the wrong track here, but if you are looking for a Gateway that supports E1 here is some info. The 2800 Series ISR (2811,2821 etc.) support the VWIC E1 Interface.
VWIC Support -- The multiflex VWIC cards are supported on Cisco 2600XM series, Cisco 2691, **Cisco 2800 series, Cisco 3700 series, and Cisco 3800 series routers when installed on the network modules listed in Components Used . The multiflex VWIC cards can also be installed in any VIC slot on the router.
From this good doc;
Hope this helps!
