'sh int' on 7604 not showing all the interfaces
Jun 20th, 2007
In my 7604, 12.2(33)SRB1, I have a couple SIP-400s with 2GE-SPAs in them. Here is 'sh mod':
ROC-RT7604A-CR>sh mod
Mod Ports Card Type Model Serial No.
1 2 Supervisor Engine 720 (Active) WS-SUP720-3B SAL1106GKP2
2 0 4-subslot SPA Interface Processor-400 7600-SIP-400 JAE1112A45Z
Mod MAC addresses Hw Fw Sw Status
1 0017.9444.68fc to 0017.9444.68ff 5.3 8.4(2) 12.2(33)SRB1 Ok
2 0015.2b89.a1d0 to 0015.2b89.a24f 2.4 12.2(33)SRB1 12.2(33)SRB1 Ok
Mod Sub-Module Model Serial Hw Status
1 Policy Feature Card 3 WS-F6K-PFC3B SAL1106GLRR 2.3 Ok
1 MSFC3 Daughterboard WS-SUP720 SAL1106G5RS 2.6 Ok
2/0 2xGE SPA SPA-2X1GE JAE11076E0X 2.2 Ok
2/1 2xGE SPA SPA-2X1GE JAE11076E62 2.2 Ok
Mod Online Diag Status
1 Pass
2 Pass
2/0 Not Applicable
2/1 Not Applicable
However when I do a 'sh int status' only the two gig interfaces on the Sup720 show up:
ROC-RT7604A-CR>sh int status
Port Name Status Vlan Duplex Speed Type
Gi1/1 connected routed full 1000 1000BaseT
Gi1/2 disabled 1 full 1000 No Transceiver
ROC-RT7604A-CR>
Yet one of the SPAs is active as shown here:
ROC-RT7604A-CR>sh int g2/0/0
GigabitEthernet2/0/0 is up, line protocol is up
Hardware is GigEther SPA, address is 0017.0fac.a600 (bia 0017.0fac.a600)
Description: to ACN-7604-CD-A G2/0/0
Internet address is xxx.xxx.xxx.xxx/30
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive not supported
Full Duplex, 1000Mbps, link type is auto, media type is LX
output flow-control is unsupported, input flow-control is unsupported
1. Is there a reason why the SPA interfaces do not show up when doing a 'sh int status'?
2. Also why does the 'sh mod' show 'not applicable' for the 2/0 & 2/1 diag status fields?
Anonymous (not verified) Wed, 06/27/2007 - 05:43
The interface may be down due to module problems.And if the interface are used for SPAN then its status will be down.
Newly added interface does not come online in a PortChannel. PortChannel mode is on.
Enable PortChannel manually or change PortChannel mode to active. Or, use the no shutdown CLI command to enable the PortChannel manually or use the channel-mode active CLI command in the interface submode for the PortChannel interface.
